Return to Index
Read Responses
Do you run your engine when you use the water maker?
In Response To:
Voltage drop
Hey Electronics Genius' ....
Dave, my first thought, based on what you've said is...
Only when..
Voltage drop
It's always been...
Watermaker is....
Then the power draw would be from pretty low voltage electronics and loads.
Voltage drop may be due to...
It's the propane switch, Brian? RFI?
Is it a propane switch or gas sniffer?
It is....
If you disconnect the sensor, what would happen?
Alternatively install a DC:DC converter to run the sensitive electronics
Ironically,......
