Alternatively install a DC:DC converter to run the sensitive electronics
In Response To: Voltage drop ()
A DC:DC converter will give you stable voltage at the electronics. It will eliminate any voltage driops due to sudden large lods unless the load draws the batteries down below the converters input voltage threshhold.
