Return to Index
Read Responses
It's the propane switch, Brian? RFI?
In Response To:
Voltage drop may be due to...
Hey Electronics Genius' ....
Dave, my first thought, based on what you've said is...
Only when..
Voltage drop
It's always been...
Do you run your engine when you use the water maker?
Watermaker is....
Then the power draw would be from pretty low voltage electronics and loads.
Is it a propane switch or gas sniffer?
It is....
If you disconnect the sensor, what would happen?
Alternatively install a DC:DC converter to run the sensitive electronics
Ironically,......
