I see that Alfa sells various antennas that can be used with the adapter/base unit (don't know what it's called). I'm assuming it's a standard antenna connection. But are Wi-Fi antennas from other manufacturers compatible? And am I correct in understanding that it's possible to hook up a remote antenna -- get an antenna with a cable, mount the antenna outside and run the cable to the adapter/base unit which can be located elsewhere?
