Return to Index
Read Responses
I'm surprised those struts aren't CF.
In Response To:
Rigging question for you mechanical engineers
From the picture it is unclear which member it is...
clarification
Then depending on tack...
There shouldn't be much load on that brace under normal conditions
Looking at the fitting attaching the brace I would say compression and that is a guess.
A tube wouldn't bend like that under tension? If multiple choice, then compression.
Read my OP
The end appears to be taped over...
In an ideal world, with the mast in column....
Thanks Jon
simple answer really, replace it. It's just a piece of tubing which can't be too hard to find but please...
That's the plan
I understood how it happened but attempted humor (rrr) about getting an exact replacement with bend and all.
The tube failed in bending -- what about the spreader?
Looks OK
Compromise
Yeah, just like a lot of life.
I bought synthetic top shrouds lst year
