Hence the dual wheels - can't make one big enough to be usable from both sides.
How come the cabin top winches look bigger than the primaries? Do they really intend to run all those mast lines under the deck? And feed them around the cabin top hatches? Should be interesting (especially only with two crew).
Those two instruments below the cabin top winches will be useless. Too far from the helm. And the only thing at the helm is a binnacle - WTF? Build a raised portion at the aft end of the cockpit seats, cushion forward, instruments aft. Duhh?
What's with that mainsheet? Is that a traveler? If so, just a matter of time until a gybe wraps the sheet around a wheel - been there, no fun. If not a traveler, why not lead through the deck, through some sheaves, and to a winch (or two). Can't be any worse than the apparent rats nest under the cabin top.
Where's the sugar scoop? Something to put my cheeks on while I rinse my tootsies. Probably: open garage door, sit on garage door. Doubt if they did as well as DDW.
BTW, don't think much of the interior either.
