Return to Index
Read Responses
Sweet boat
In Response To:
salon photo ...last shot
Les, that is an amazing interior layout. So much room. How does she sail?
Salish Sea Pilot's free cruising guides
flat spot in hull
How much of a deflection? Is it near a stringer or bulkhead? How near the waterline?
Is it cored?
If it is cored and crushed, it is a different issue and needs to be fixed.
Agreed
yes, it cored
Grind, replace core, re-glass, barrier coat, bottom paint
Or cut out surface
In either case
I'd give it a bit of time, maybe some heat to warm the area a bit.........
Bondo?
I would have a yard look at it.
repair
What design is that?
Tartan
Interior
Wow! Thanks for the photos. A most spacious interior indeed!
Ditto! That's a big 42'er. Clever layout for liveaboard.
Looks very nice
Sweet boat
how does she sail?
One last thought about the repair
I don't like the idea...
NOT 5200, epoxy if you're going to that method.
P.S. Top hole and bottom hole only the size of the tip of the syringe, about 1/8" diameter or so.
If you had gone ahead with the repair when you started this thread...
Very nice. We had a T37 and it was so much smaller inside
So, how many more old boats are you gonna buy...? (grin)
Thank you all, I have the plan now with..
