Return to Index
Read Responses
A Bavaria rudder (whose skins peeled off)
In Response To:
Most of the spade rudders I have seen are not built as you describe
Interesting comment by Charles Doane on his blog
I saw that. The gremlins in that story are inside those rudders.
I propose a different (and more likely) failure mode...
Your hypothesis is plausible
I've been surprised by a couple of comments made in follow up to this event...
I'm not. The experts a thousand miles away always make the most noise.
You're right, of course - but I was actually thinking of Charlie's subsequent comments/clarifications (grin)
Ahh. Close reaching vs. fore reaching, 4 kts. vs. 6 kts. 'considerable discrepancies' between captain and crew?
Don't disagree with your first comment at all...
Don't forget the simple stuff, 2 rudders folded up on this new boat as it was going through the water.
Well, by the same token, don't ignore the obvious... (grin)
I think a new rudder should put up with any force the water applies.
Doane says the shaft was not bent.
I think we're approaching "it depends what the meaning of 'IS' is" territory, here... (grin)
I can see it
Yes, it's finally occurred to me...
While I don't think the description matches, one explanation
Your picture isn't typical production rudder construction.
One more
The skin was mostly removed on land, I hope?
No, the skin was lost while just sailing along in nice conditions
Amazing. Wonder if that was closed cell foam?
Nevermind, I just reread your description
DQ
Wrapping it would allow more weld area...
It probably would have happened anyway
Surfing 25 knots in reverse, isn't relevent to my point, Mark.
Don't underestimate the forces...
Yes, of course I have. And the rudder should be designed for this.
I was agreeing with you Tom
You are right - it should not...
I would hope all of them do
Would it be unreasonable to design a rudder that
The forces in a seaway are very different than in "quite waters" situation
Thanks.
That rudder was built for the Spirit of Bermuda, a sail training vessel out of Bermuda.
Well Jon, as has been pointed out, I'm no engineer
Here's the cached page
