Put a polyethylene tube on the end of the caulking tube...
an HDPE poly tube will be stiff enough to direct where you want the sealant to go, foot long or more not a problem. You want it big enough (like 3/8 id) so that you can still pump the sealant through it.
I assume you already know that the proper way to do this is to remove the box, clean it, and reseal.
