Yes you have it..
In Response To: Thanks Rodd ()
And to create voltage drop in a circuit you need amps...... Try for 80% of what the circuit is rated for if possible or just the normal load.. Ideally if we had no voltage drop the end to end reading under load would be 0.000V. When you have current and long wires you will invariably have some drop. Combined circuit drop should be less than 3%...
