Return to Index
Read Responses
Wow, fast on spade connectors...
In Response To:
I just corrected the same problem on my sailplane....
hate to think of one wiggling loose due to vibration, while you are aloft.
Voltage Drop
To eliminate any sneek circuits that
Please explain a bit more
Like Al said below, if you're looking for
Yes, measure the drop directly.
Larry ...
Thanks Rodd
Yes you have it..
Figured out my voltage drop
And probably not gold-plated
It's a sailplane (it's the landing ;^))) )
And this in fact had happened to me....
LOL makes the gliders much like a sailboat
Update on the poor connection
Crimps...
Plier style
I just use a pair of vice grips...
It'll work in a pinch.....
No photo above...
I use a GS crimper - rachet type
The absolute best crimper is the TE connectivity ratchet part #69710-1
