Return to Index
Read Responses
And probably not gold-plated
In Response To:
Figured out my voltage drop
Voltage Drop
To eliminate any sneek circuits that
Please explain a bit more
Like Al said below, if you're looking for
Yes, measure the drop directly.
Larry ...
Thanks Rodd
Yes you have it..
I just corrected the same problem on my sailplane....
Wow, fast on spade connectors...
It's a sailplane (it's the landing ;^))) )
And this in fact had happened to me....
LOL makes the gliders much like a sailboat
Update on the poor connection
Crimps...
Plier style
I just use a pair of vice grips...
It'll work in a pinch.....
No photo above...
I use a GS crimper - rachet type
The absolute best crimper is the TE connectivity ratchet part #69710-1
