the manufacturer's idea of power distribution was to daisy chain the power through a bunch of crimped Fast On type spade connectors. Good aircraft designers, bad electricians. Bad idea to start with, compounded by bad execution: if you must do that, why not at least feed the daisy chain from the middle? As you did, I replaced it with a proper buss bar.
