Return to Index
Read Responses
I just use a pair of vice grips...
In Response To:
Crimps...
Never had one fail.
Voltage Drop
To eliminate any sneek circuits that
Please explain a bit more
Like Al said below, if you're looking for
Yes, measure the drop directly.
Larry ...
Thanks Rodd
Yes you have it..
Figured out my voltage drop
And probably not gold-plated
I just corrected the same problem on my sailplane....
Wow, fast on spade connectors...
It's a sailplane (it's the landing ;^))) )
And this in fact had happened to me....
LOL makes the gliders much like a sailboat
Update on the poor connection
Crimps...
Plier style
It'll work in a pinch.....
No photo above...
I use a GS crimper - rachet type
The absolute best crimper is the TE connectivity ratchet part #69710-1
