If you want tried-and-true solution...
In Response To: As delivered, our Sabre... ()
Use a simple pump (not a recipricating model, like the "old" PAR pumps) with a simple pressure switch (I've use Shurflo 4 gal/minute, you might use the 2.8 gal/minute). Use a prepackaged accumulator tank.
