Return to Index
Read Responses
I'm not speaking of the variable speed pumps. Have you heard of complaints about the single speed Shurflo's?
In Response To:
I haven't had any trouble with the Jabsco ones...
Fresh water pump...
You don't have and expansion tank?
As delivered, our Sabre...
If you want tried-and-true solution...
Our Shurflo variable speed just bit the dust
This is exactly what I was hoping to learn.
Our Shurflo with expansion tank has been trouble free since 2002
I put a light ...
happy Shurflo customer
I'm sure the non-variable speed ones are rugged
well now, just to be different...
If you go with the larger (more power hungry) and robust capacity constant volume pumps, low flow shouldn't be an issue.
Arent most shower heads restricted to something like 1.5 gpm???
I believe you're right and most people blow off
That's a good deal
That's nothing, she sands and lays the vanish
Motel shower
