buying a different/new boat is that their is never a perfect boat! You can get close but it's not going to be perfect. Get that burned into your brain and then move forward. You have to find the boat that mostly works and doesn't have the qualities that really bother you. I've had Brendon for almost 20 years because she "mostly" works for me and the things that I would like to change about her are things that I have learned how to work around. Good luck with trying to find the perfect boat.
