I have a spare shaft zinc stored on the shaft snug up against the rotor. The rotor is secured to the shaft by small set screws that can slip. The zinc is clamped hard to back up the screws. You could also use a hose clamp.
Mine did slip shortly after installation, but since I added the zinc it has stayed secure.
