Return to Index
Read Responses
I would think 3 inches would be enough for day to day use
In Response To:
how much take up do you think Adam is going to need? (nm) (link)
but I would add fittings for lashings, for periodic long-term adjustment if required.
Spectra for staysail instead of wire???????
spectra stays for staysail
metal hanks vs. softies
Do you need hanks???
Look at Wichard snap hanks instead of traditional piston hanks (nm)
We changed our 750 sq ft reacher to bronze Wichard hanks and like them (nm)
They are a bit difficult to work since there is zero stretch in the line. (pic)
Dynex Dux for staysail
Tensioning Dux stay?
Just a suggestion, but I bet you could get a lot of tension with a Spanish windlass
before wire, every boat was rigged with rope. It's nice to see old school technology still being used today... (link)
turnbuckle
turnbuckle options by Johnson
Johnson Marine makes great rigging hardware. You can't go wrong with their adjusters. (nm) (link)
I don't know why you guys think you need that much adjustment
adjustment length
What's wrong with a nice 4-1 amsteel tackle to tension it? Hell it's alot easier to deal with than tightening a trnbkl .
block/tackle tight enough?
I guess I'm thinking that because it's an inner forestay, The main times there is a sail involved is reaching or ...
Getting tension (pic)
stay tension
