Return to Index
Read Responses
And the starter motor has a large gear reduction, torque is also important
In Response To:
Spring-driven
Is this a Crazy Idea?
Theoretically,
Those 18v'ers sure have a lot of torque. Try it and let us know..
starters
I tried this
You can also get one of those 90 deg. angle heads
Why can't you
Spring-driven
Ron, here's what you need to do: the mainsail starter
thought it was ingenious when I first heard of it...
Yves Parlier's story of fixing his carbon mast in the Vendee Globe in 2000 was as an amazing story, too...
And to think just yesterday I had seaweed soup...
Never tried it, but the idea of crank-starting anything more than a one cylinder diesel has always scared me...
hand crank
Thanks, Rich - figured there had to be some ratcheting device or similar for a bigger engine...
12hp would break an arm easily
In the past I have hand started my old IIA Land Rover
My dad's old
Cranking a diesel and Series Rovers
Unfortunately the original poster has a Volvo 2003 and it only allows all 3 compression releases to operated as one.
I think they say it has one for each cylinder.
All connected to a single lever.
unfortunately new diesels
Trip South?/
How is your engine repair going Jon?
Until Kettering's invention that was the most dangerous part of driving a car
Starters
