Return to Index
Read Responses
Yeah, it looks more like the "don't" picture
In Response To:
Maybe he was thinking above WL.
Is this head/holding tank schematic accepted?
I dunno Tom
I don't like that diagram...
I think I'd want a loop in there...
I wouldn't omit the loop in that installation..
I'm convinced. I don't have much volume above WL.
Put tank above waterline?
Loop it or lose it!
You don't need the Y valve....
Good point on the Y valve. And the pump is a consideration.
Don't you also need a vented loop between intake and head, if the top of bowl is below waterline?
Yep...but it has to go between the pump and the bowl...not between the intake thru-hull and the pump.
Don't put the pump below the water
Don't put any of the fittings below the waterline where avoidable
I don't like the idea of
About that pump...
