Return to Index
Read Responses
Looks like some 45 degree fittings ;^)
In Response To:
The view from below the shelf...
Sanitation Hose Question
Do you have space for two 90-degree elbows and the short connections to provide offset?
The sanitation hose I used is too stiff for it's own good.
WOW... that is expensive....
No need to spend that much...
I just replaced 10yr old Trident 101
Ron, I'd use one or two 45 degree fittings with some hose
Another idea
Thanks for all comments and suggestions!
Belatedly, my SCH-40 zig-zag...
Wow! You mean these adaptors go to regular Sch 40 pvc pipe Dave?
A-yah
You can also use standard household sink "tail pipe". Perfect size.
I wouldn't use that in a marine setting with waste
That is great to know. I'm sure it's pricey but who cares when you need to bend.
Defender used to carry them; not listed now.
You can also use standard 1 1/4 SCH 80 PVC....
Okay, I have to ask a couple things
No macerator...
Thanks. One more.
Perhaps an annotated picture would help...
OMG! Thanks.
Nice work! Sometimes you just want to get the right part though, and skip a trip to the lathe.
Clearly you are not a tool-o-holic....
Maybe even a 22-1/2!
I REALLY hope your through-hull fittings
How about bronze? ...
I knew that's what you probably meant
