Return to Index
Read Responses
That sounds really interesting Craig
In Response To:
Cleaning
Do you think it would work on mildew stains in sails?
REPOST of deleted NO SOAP message
That sounds like a very unpleasant
Eco-thugs. For something to become clean -- something else must become dirty.
A pressure washer will do a pretty good job
A pressure washer with bedded deck fittings or trim, hatches?
Larry, you know that with a pressure washer you do have some discretion...
Yes of course...
Cleaning
Mildew
any thoughts on Simple Green?
NOTHING is to flow from the deck to the water
sounds like a full deck awning might keep the soot off...
hell, my thinking is that they should go after the guys responsible for the fine mist of grey/black soot and diesel...
I doubt it
And then they will...
I was somewhat "T in C" ... but your right
A few years ago activists from P E T A....
I think a water cannon would work
Jessie Jackson School of Social Engineering
The Taliban Branch of the Green Movement, as you term it, isn't nearly as bad as the
Jud, I agree with you
I was just being a bit over the top there
Well as long as their hearts are in the right place....
My point being, their intentions are good, their tactics are not
