Return to Index
Read Responses
sounds like a full deck awning might keep the soot off...
In Response To:
NOTHING is to flow from the deck to the water
REPOST of deleted NO SOAP message
That sounds like a very unpleasant
Eco-thugs. For something to become clean -- something else must become dirty.
A pressure washer will do a pretty good job
A pressure washer with bedded deck fittings or trim, hatches?
Larry, you know that with a pressure washer you do have some discretion...
Yes of course...
Cleaning
That sounds really interesting Craig
Mildew
any thoughts on Simple Green?
hell, my thinking is that they should go after the guys responsible for the fine mist of grey/black soot and diesel...
I doubt it
And then they will...
I was somewhat "T in C" ... but your right
A few years ago activists from P E T A....
I think a water cannon would work
Jessie Jackson School of Social Engineering
The Taliban Branch of the Green Movement, as you term it, isn't nearly as bad as the
Jud, I agree with you
I was just being a bit over the top there
Well as long as their hearts are in the right place....
My point being, their intentions are good, their tactics are not
