When we were in the Chesapeake I found the amp hours about a 1/3 less then down here in the tropics. When the water temp is lower, the boat temp is lower, when the air temp is lower the box doesn't work as hard. I don't care how much insulation you have!
Go Slow
Sail Far
Stay long
