Return to Index
Read Responses
Wow, impressive getting 24A from 250W of panels!
In Response To:
Solar panels
Did you have a MPPT regulator, or maybe a big magnifying glass ?
Cheers,
John.
Solar cell performance update for no particular reason....
Sounds great. Don't walk on them.
But what's the bottom line on 'in & out'
Between 50 and 100 AH/day...
Pretty good at low consumption.
I had the opportunity to start from scratch
Remember where his boat is.
Yeah I would think refrigeration would be the big draw...
Daytime temps have been 28 - 32 deg C
MPPT and temperature
Not sure I understand that...
Solar panels
Solar panels
I guess my panels are really inefficient
YUP! fixed position is NOT the way to go!
The devil is in the details
The devil's in the details.
Sorry, couldn't resist a little ribbing about your exagerated output.
Your panels are far exceeding their rated maximium output if they put out 22+ amps
We get about 8.5 amps max from 8x20w panels (160w)
I have this image in my mind of cruising into some isolated bay in, let's say, Ecuador and
Sports or boat systems? What's the diff?
My point was humor -- I'm not sure how long I'd last on the
The trick is to not go far from an ice machine Jud.
Milliamp draw on Engle fridge? You are drawing far less than the rated output of the motor
the Engle draws less than 1 amp average
Sweet.
Where do you put it?
A beer cooler is never in the way -- are you nuts?
We put ours where the icemaker once was
That's a really nice fit
It gets a bit warm behind it
In the tropics
1.9 average is almost as much as my big Vitro Frigo
Remember that panels are rated at low temperature
