Can't directly answer
But the Monitor had a pressure toilet that was the precursor to the heads later used on submarines.
Make sure the outter door is closed, open the inner one at the bowl, do what you need to do, close the inner and open the outer and pressurize to flush.
Not something you would want a drunk to use.
