Return to Index
Read Responses
Yeah, but that was from being in the water.
In Response To:
A friend used this on his outboard power boat.
Tropical Dance Website
removing stains on fiberglass?
Use FSR or other acid-based stain remover...
Also, Easy-Off is a good paint remover, FYI
I've had no problem with the 'boot stripe'
You talking about Easy Off or On and Off?
This stuff
Oxalic acid? Google Oxalic acid effects on body. You'll wear gloves in the future.
So,,, that's why I always got dizzy!
That was for 'Occupational Health Guidelines'
mostly muriatic acid
Opened my eyes.
MSDS
Easy Off
So you decided to play John Dillinger ;^)
Try 'On and Off' available at any chandlery.
'On and Off' is another acid. Be careful with it.
Absolutely right. Wear protection including eyes but, it works great.
removes rust stains???
great for rust. Razor blade for varnish
digging in the troughs...
Try a tiny wire brush in a Dremel
"Any Chandlery"?
FSR results
Did you try Oxalic Acid?
lemon juice
