FSR results
In Response To: removing stains on fiberglass? ()
Not the fastest process but after three applications of Davis FSR, each remaining on for about 20 minutes, the stains are looking much better. I figure that two more applications should do the trick. On the other hand, I messed around with some of the scum stains at the water line and they vanished with only one application. So, all in all, this stuff seems to work as advertized.
