Return to Index
Read Responses
Yes, I have quite a few Bebes - no problems.
In Response To:
Hand Made isn't necessarily a problem
LED research update
Dr. LED has bulbs certified in certain Aqua Signal fixtures
We have the series 25 lights
So you are saying that ...
If I read their press release correctly, no.
Why don't you call or email them, Craig?
It is specific to the Aqua Signal series 40
Re: Series 25
What was the issue with the Lopo lights?
They just keep failing...
We finally had one fail
Geez, it seems so hit or miss on LEDs. I was planning to......
No need to spend a lot of bucks
LED's are hardly "bulletproof", yet.
Anyone have any issues with Aquasignal's own LEDs?
Hand made unreliability...
The only problem with the Bebi lights is physical shock
How real is the concern about certification?
It becomes an issue if you are involved in an after dark collision...
Agreed
I doubt the "correct" bulb will deter some idiot from running into you...
Thats not the point.
Tom, the way I see it it's just another check-box
Craig did you see these when looking into LED
If the light was certified with a colored lens
Jeramy - In a Kelvin Scale -- white isn't just "white"
The Bebi LED electronics site has a good write-up on this
Fascinating read . . . but my suggestion was that the lens
Different colored light (K) will cause colored shift through the colored lens, Jeremy?
I am not familiar with this one
