Anchor Windlass
I agree with Brian! You need a much bigger anchor windlass. There will come a time when you cannot motor up to your anchor and yet U must pull it. If you snag it and your winch is of sufficient power you might pull its snagged portion close enough to free the anchor. Bigga damn cable on both side of battery to windlass are a must. We used welding cable for TPIII.
ole salts view
geneWj
