Return to Index
Read Responses
The rated maximum pull of your windlass...
In Response To:
I really don't get the boat size rating
should be at least four times the total weight of your rode, chain, and anchor...
Battery bank question
The house bank was likely split...
I'll bet it was left when 12 volts were switched to 6 volts
I can see that advantage
I wonder if you can check the start battery?
Been there, did that.
The only thing I can think of is
Agree-- leave in the switch.
Hi Tom. How's the new boat?
It's working out well so far
Nice. What's wrong with the centerboard and trunk?
The CB drops too far forward and has damaged the trunk
Old, outdated concept..
I looked at the specs for your windlass...
Anchor Windlass
Thanks for all the advice and wisdom
Windlass' are like Maxprops...
Which is what? without a debate on whether or not it's too small (I concede, it's pushing the limit)
In the worst case...
