Until you have one, you never realized what you were missing.
On the other hand, as a weekend warrior you are probably right about usage. When I first looked at the specs of your anchor, I was shocked that someone could make a windlass with so light a pull.
I disagree with the concept of a battery forward. This has been discussed to death here and elsewhere so I won't repeat it.
