yes - have done it several times
in nasty weather, on the Atlantic side - safe is a relative term - came last year w/6-8" swells - a little tense, but the fairway is very wide and approach is not hard - the Delaware side is as described, and is very shallow near the ferries - plus the mast issue - also don't overlook Barnegat Bay, as that also is not as bad as advertised, assuming the tide is slack or with you
