The Frances is a boat designed to a whole different set of parameters starting with an optimal hull shape available in the LOA. Once accomodations start pushing the hull to a new shape, you're going to start losing that optimal seagoing hull shape. There's nothing wrong with doing that(boats are compromises through and through, the Flicka is a good compromise), but you can't have both, there's no free lunch.
