http://snowpetrelsailing.blogspot.ca/2011/02/high-latitude-dodger.html
1 - 18 inch 6mm perspex dome, absolutely amazing view, doesn't steam up and can be used from inside the hatch or inside the cockpit. It is high enough to have a good view forward. It is a feature that I wouldn't be without. For tropical sailing I might fit it onto a hatch so it can be removed.
Little green hatted man is warm, dry and very happy!
2 - Hand rails set inboard to serve as longitudinal stringers, and gives a comfortable seat on the edge of the dodger roof. By setting them inboard the are easy to hold onto when on the lee deck.
3 - The dodger top is 2 layers of 6mm plywood laminated into a curve. It also has glass sheathing and non skid paint. This is more than strong enough to jump on. I intend to put a mainsheet traveller on top of it at some point...
4 - At the aft edge of the top and the sides is an external laminated beam. Inside this is an aluminium boltrope extrusion to take the canvas flap, to close in the dodger. This Beam stiffens and strengthens the top. It also stops water blowing back from the dodger top into the cockpit. And It forms a good handhold, hence burying the aluminium track inside the wood to stop my fingers getting cold.
5 - Big plywood and glass knees strengthen the aft end of the dodger, they also have handholds and make a nice backrest, or place to lean against. They also give the canvas flap something to overlap to stop rain driving in.
6 - Cabin top is used as a step to get onto the dodger, it also makes the dodger look better to set it slightly inside the cabin edge, and it is easier to build.
7 - Windows are 4 mm perspex, designed to break before the dodger does...
8 - Dodger sides are 9mm ply, doubled in high load areas, with heavy biaxial fibreglass tape in all the corners. They are bolted through welded stainless steel tabs on the cabin top. a Sikaflex fillet seals it to the deck.
