Propane has no shelf life.
If you fill up a tank the shelf life is determined by how long the tank will stay in one piece without venting the propane through a pin hole or leaking valve. If the tank is shielded from weather and doesn't leak, the propane could last more than 100 years.
Now that's piece of mind on long term storage.
