Turns over fine. Acts like it is going to start, makes noises like it is going to run, then just dies. Even spat out exhaust with water like it should.
I probably need to go back and do the bleed procedure again slowly and more carefully. Greg D tells me I should bleed it carefully... more like brake lines. I didn't do that... I probably allowed air back in.
Then the next time I try it, I have to tie my hand behind my back so I don't automatically open the raw water again.
