is around 2940 windmills. I also spoke without giving thought to the real environmental questions. So lets thing about the thousands of miles of undersea wire that will have to be laid on the seabed to connect these monsters to the mainland. The anchors that will have to be drilled into the sea floor to hold them in place. The hundreds and hundreds of miles of grounding grids buried in the sea bed. Lets think about the smaller substations spread out along the coast to accept the off shore cables. Maybe you'll be one of the lucky ones who will get one in front of your house so you can enjoy that view as well. Lets think about the industrial harbor that would have to be built to support the work boats that all of these ex fishermen turned into high voltage electricians are going to work from. As for fishing in the area, forget it. The entire area will be off limits because of the danger of snagging an underwater cable with an anchor or net. There will be shipping and transit lanes through the mess for mariners with off limits areas for the rest of the site. Still like the idea?
