Return to Index
Read Responses
What are you using directly into your ipad, (You're using Garmin Bluechart app?)
In Response To:
Why don't you just install a chart app on the ipad, Blye?
What chart plotters/GPS units will co-display on an ipad?
Furuno or Raymarine
I saw that, but d haven't looked into it up-until now. Do all newer GPS Plotters re-send info via bluetooth for ipad?
No
I guess what I'm asking, is there anyone that can recommend a reasonably priced unit?c
We have had very good success with
And that can connect wirelessly to an ipad? D
I do NOT think so, but your last note...
That's okay... if I'm going to upgrade I want the additional connectivity.
Bluetooth connectivity.
Funny, I'm choosing all my electronics based on Ipad compatability.
Yes. Then our external gps, through blue tooth, plots our location on the charts.
No, ipad is just WIFI... (I'm a Pirate.... we're a tad on the cheap end.... spend money on a cell enabled ipad!!!! LOL!!
Same boat here. There may be a small plus or two to an external gps reciever.
If you're buying an iPad for navigation, get the model with GPS
Even better buy a model that uses Android...
Hey Nat, are the tablets cutting into Chartplotter sales?
No doubt about it.....your situation is a
That's true.
It could be a collectors item one day.
Read Google's terms of use
How is it different from the Apple terms?
You might be able to find a comparison if you search the web
Larry....I don't care if Google or the NSA tracks me....
You don't care about right to privacy?
Have you read Google's terms Larry?
Any organization that tracks people's activity
On one hand Larry.....
Yes I've read their terms
Google invaded Portland Maine, by water.
That's better than this
They could at least have painted the barge!
One in San Francisco also....
Furuno
Lowrance HDS Gen2 touch will work with it via WiFi
Lowrance can't even get their own software right
I have had zero problems with my HDS gen1
Are you using their crappy charts?
Yes, they are fine for where I sail
Simrad Go-Free wifi
For less than that $200
