Stand on vs give way.
The way I see it. There are two time frames in which the stand-on boat should maneuver. Just in time to avoid a collision and when the boats are at least 5 minutes or more (depending upon the size of the other boat) apart. Usually, a course change of just 5 or 10 degrees early enough can avoid the crossing situation altogether. This is my preferred way.
