You can see the port side LED docking light just forward of the registration sticker in the image below. They are bright enough to light up a slow approach to a dock or mooring, or to check the status of the bridle at night, and it really helps to have the light source below deck level so there's no deck glare. I also replaced the 55w deck light with an LED floodlight bulb that draws less than 5w.
