Return to Index
Read Responses
Why stow it... there was a "retention system."
In Response To:
Nice lamp.
Anyone have Alpenglow's LED Reading Lights ...
Yes, since 2011
I have a chart gooseneck light with Alpenglow in'ards...
I replaced every one of my bulbs on
I replaced mine with LEDs too
I also added LED docking lights
Nice... I thought only powerboats used headlights.
You're right
Larry, on that deck lamp...
Mine was a PAR36 bulb
Yep, that's it. There do seem to be some 12-24V models available.
BTW G4 is another popular bulb base
Dimmable LED's concern me.
I have Alpenglow dimming light at nav station
Aspenglow makes 2 brightness level reading lights
I like your thinking there... but a combination might be the best answer
Agree, I believe a combination is the answer.
Have been reading with cheap LEDs
Installed LED lights for reading on Jaunty with 18 LED's, warm white.
Yes I buy "warm white"
I have pretty much the same lights on Tehani. They work well for reading.
lights affect different people different ways...
A big missing feature of LED's no one has mentioned.
agreed... which is why I think a mix of lights is the best answer.
Have you seen the LED candles?
We had a set of 3 mounted in pebbles
Good Old Boat had an interesting article in March 2012 (issue 83)
Trawler lamp
Nice lamp.
It looks like it might whip around
My trawler lamp
Retention system tames it... when connected!
I use my lamp a lot, even though I have nice LED reading lamps
That is only true for PWM dimmers
You never had that concern with film movies?
Yes, a bit.
On the plus side I use my vision to find problems...
My eyes aren't good at all but I get 100% on that test every time
And color blindness CAN have strange benefits- Used to work with another
We've been dimming
Another use for LED lights is the new
They're even available now for the old household base marine lights.
