guess I should not have lubricated everything... SIGH. Just trying to keep corrosion to a minimum.
The throttle holds OK at low RPMs, and at high RPMs, but in the area I use it the most... it slowly slips down to an area I don't use it much. Guess I'll have to find that adjustment screw and give it a little tweak.
Funny, screwed by trying to do the right thing.
Oh yeah, the engine is in fine shape... purrs like a sewing machine. Runs through the whole power range just fine.
