Return to Index
Read Responses
Edson pedestals do not.
In Response To:
Most control levers have a set screw to adjust friction...
Feedback on governor problem, please
Does the engine run well other than that?
The engine runs fine otherwise, I do think it's the governor
My Morse did that also
Yep, exactly
Governor
What kind of Morris cable box at the helm
Edison pedestal, and it has a tensioning adjustment
Max, on the governor, is there a spring that
Max, this is a very common problem ...
I always wondered why my throttle cable had a wire clamp on it.
Yeah, I just developed this problem too...
This summer's problem? Last year it was dirty fuel.
Well actually last year it was a clogged exhaust.
I swapped lots of fuel system parts.
I wish "one shouldn't motor that much..."
Don't we all. Or at least many of us- 4 miles up a 60 foot wide channel
Brian has a good idea
Way to go, Max! Lynnie's blog is wonderful, great pics, I'll definitely be following you guys, best of luck
One more thing....
