Return to Index
Read Responses
This summer's problem? Last year it was dirty fuel.
In Response To:
Yeah, I just developed this problem too...
Could do without another serious issue!
Sailonset
Feedback on governor problem, please
Does the engine run well other than that?
The engine runs fine otherwise, I do think it's the governor
My Morse did that also
Yep, exactly
Governor
What kind of Morris cable box at the helm
Edison pedestal, and it has a tensioning adjustment
Max, on the governor, is there a spring that
Max, this is a very common problem ...
I always wondered why my throttle cable had a wire clamp on it.
Well actually last year it was a clogged exhaust.
I swapped lots of fuel system parts.
I wish "one shouldn't motor that much..."
Don't we all. Or at least many of us- 4 miles up a 60 foot wide channel
Brian has a good idea
Most control levers have a set screw to adjust friction...
Way to go, Max! Lynnie's blog is wonderful, great pics, I'll definitely be following you guys, best of luck
Edson pedestals do not.
One more thing....
