a small crack in my bow sprit. I have a laminated teak platform which is developing a separation in a seam between a couple of the vertical 2 by 3 inch planks. The platform is varnished and while I'm preparing for another coat I'm going to try and solve the problem before it get's any worse. I'm thinking about using some penetrating epoxy like "git-rot" which should seep into the crack/split and do the job. What say you all? Thanks,
