Return to Index
Read Responses
Concur with heat. Go Charlie!
In Response To:
Also, something I've done on occasion- Mix the epoxy straight, use a hair dryer to heat the stuff in the container
"OK--wood experts--how do" Fill up and seal
Nope. Git rot is designed to harden rotted wood, NOT as a repair for cracks
The "crack" is almost like, not even a crack. It's almost
Sounds like you gotta widen out the crack a mite.....
True! Sometimes you have to run a hand saw through a crack in wood.
Yup - I would...
Straight West Systems.
Does Straight West System come
Our crack started as very small.....
Yes, you can get "repair kits" that come with everything needed, in small quantities. Here's one link
I would suggest caution.....
So you are tring to fill a seam that is opening up.
The acetone is a good idea and I'll use it
If the gap is that narrow
Flushing with acetone, etc.
So, after reading all the posts here, this
Then go sailing?
I agree with routing out and using a Dutchman because
