Also, something I've done on occasion- Mix the epoxy straight, use a hair dryer to heat the stuff in the container
which will thin it drastically and it will flow very easily. Be SURE you are ready to roll though, because it also accelerates the cure in the mixing cup. Mix small quantities.
