Return to Index
Read Responses
Yes, you can get "repair kits" that come with everything needed, in small quantities. Here's one link
In Response To:
Does Straight West System come
http://www.westsystem.com/ss/repair-kits/
Runs in the neighborhood of $30
"OK--wood experts--how do" Fill up and seal
Nope. Git rot is designed to harden rotted wood, NOT as a repair for cracks
The "crack" is almost like, not even a crack. It's almost
Sounds like you gotta widen out the crack a mite.....
True! Sometimes you have to run a hand saw through a crack in wood.
Yup - I would...
Straight West Systems.
Our crack started as very small.....
Also, something I've done on occasion- Mix the epoxy straight, use a hair dryer to heat the stuff in the container
Concur with heat. Go Charlie!
I would suggest caution.....
So you are tring to fill a seam that is opening up.
The acetone is a good idea and I'll use it
If the gap is that narrow
Flushing with acetone, etc.
So, after reading all the posts here, this
Then go sailing?
I agree with routing out and using a Dutchman because
